Activity Forums Adobe Premiere Pro “paper edit to sequence workflow”
  • “paper edit to sequence workflow”
    Posted by Tony Brecknock on February 21, 2014 at 4:20 pm
    I have a few outside producers working from time code windows, know of anything that will create an edl or project or file to bring into premiere pro so they can type into it and I don’t need to redo the editing from the raw clips?
    Tony
    Al Levine replied 12 years, 7 months ago 2 Members · 1 Reply
  • Al Levine
    February 21, 2014 at 8:57 pm
    I don’t know if there’s going to be anything easy… either way you’ll have to format their notes.
    Might as well type in the timecode, IN, type in the OUT and insert.
    You could also hire an assistant editor to do the stringout based on their notes, then come in when that’s ready and do the fine cut. That’s usually the workflow with anything I’ve worked on.
    In the future Adobe Prelude might be in the stars for you… I haven’t messed around with that too much though…
