Activity › Forums › Adobe Premiere Pro › Panoramic photographs
  • Panoramic photographs
    Posted by Luke Ball on January 23, 2010 at 1:23 pm
    Hello
    I’m making a video which also contains still photographs. I have a combination of square images and panoramics. When I export the squares after clicking scale to frame size, they are perfect. however if I try the same with the panoramics they are extremely low res. the files are fine viewed alone, and I have tried manually scaling them but I still have the same problem?
    If anyone can help it would be greatly appreciated.
    Thank you
    Ann Bens replied 16 years, 8 months ago 2 Members · 1 Reply
  • Ann Bens
    January 23, 2010 at 3:59 pm
    Make the still the same resolution as the project/sequence settings before importing. See if that helps.
