Panning and zooming on HD footage that ends up on a DVD
I used to be able to do this quite easily on Premiere Pro but I’m not sure I understand what’s happening now.
My ultimate destination is a DVD. I’m shooting AVCHD footage (1920 x 1080) and in some fairly static clips I want to be able to pan and zoom. I imagine other people do this from time to time?
In Premiere I’d just create a new sequence setup with 1280×720, select all clips from my edited 1920 x 1080 sequence and paste them into the new sequence. At that point all clips would be automatically zoomed in and showing a scaling factor of 100%. I’d choose a clip, change the scaling to 66.7% (which would show the clip correctly in the viewing window) and then copy and paste attributes of that clip to all other clips in the sequence. Then I’d go through the sequence and pan and zoom certain clips up to maybe 90% – so as to feel safe although I suppose I could have gone all the way up to 100%?
Now, in FCPX, I tried creating a new project with Custom settings of 720p HD, 1280×720 and 25p (although the footage shows as 26i – does that matter?)
Anyway, I drag a clip into the new project and it appears at normal scaling i.e.. I see the whole image not just the middle zoomed in as I would in Premiere. In the Inspector, under the Info tab, I see the clip still has it’s 1920 x 1080 characteristics although it is in a 1280×720 project.
Assuming that FCPX has saved me the image rescaling step and that it’s doing what I hope it’s doing, how much do you think I should be able to scale up clips (from 100%) without them going too obviously ‘soft’? Or doesn’t it work like that…?
I hope this all makes sense. Many thanks in advance for any advice in this area.
FCPX and PPro 6. iMac 24 + MBP 17″. Near Geneva, Switzerland
