Activity › Forums › Apple Final Cut Pro Legacy › Panned audio
Panned audio
Posted by Bryce Douglass on August 28, 2010 at 11:41 pmIs there a reason why music etc is panned when imported into final cut?
Bryce Douglass replied 16 years ago 3 Members · 10 Replies -
Rob Grauert
August 29, 2010 at 12:25 ambecause it’s stereo. One channel is panned left (-1) and the other is panned right (+1)
Rob Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com -
Rob Grauert
August 29, 2010 at 12:48 amIf you have a mono track, panning it center would give you dual mono – the same audio coming out of both left and right speakers.
If you panned your stereo tracks to the center, I suspect it would do the same. Give it a try and look at your audio meters. See what happens
Rob Grauert, Jr.
Bryce Douglass
August 29, 2010 at 1:08 amYeah it does. I guess I am really wanting to know is should i pan my camera recording to match the music audio also? I have video that records on a sd card and when I import it it’s panned. Should it be panned or not?
Bryce
Rob Grauert
August 29, 2010 at 1:27 amYour camera is most likely recording stereo audio. So leave it as is – left channel panned to -1, right channel panned to +1
Rob Grauert, Jr.
Bryce Douglass
August 29, 2010 at 1:42 amI don’t have two options. I only have -1 I can’t do both. Sorry if I’m confused.
Bryce
John Fishback
August 29, 2010 at 3:20 pmIn Log & Transfer or Log & Capture you’ll see a button with a symbol to the left of the audio tracks. There are two lines from it going to 2 tracks such as A2 & A2, A3 & A4, etc. This button determines if the two track will be transferred/captured in mono or stereo.
Do you have one or two tracks coming in? If two, are they linked or unlinked? Have you tried double-clicking one track and changing the pan setting in the Viewer to +1?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Bryce Douglass
August 29, 2010 at 4:07 pmthat’s great but I’m not capturing anything. I’m shooting on a SD card and then dragging clips from the SD card onto my external drive and importing them into final cut.
Bryce
John Fishback
August 29, 2010 at 4:42 pmWhat camera are you using and what kind of file are you importing directly? If there’s a log and transfer/capture workflow, you might try that. Have you tried double-clicking one of the imported clips and changing the pan position of one of the audio tracks? You have two audio tracks, right? And both are panned left?
John
Bryce Douglass
August 29, 2010 at 4:51 pmyes but I heard that it makes no difference and I tried and I dont’ hear a difference.
Bryce
