Activity › Forums › Adobe After Effects › panels folding out
  • Erik Waluska
    April 22, 2012 at 4:51 pm
    If you have each solar panel in its own layer in your AI file then you can bring it into AE as a composition and choose the “retain layer sizes” option. You’ll have to change the anchor points of each one so that it’s on the edge that you want to use as the “hinge” for the fold out animation. Just use the Pan Behind tool (shortcut is Y) to drag the anchor point in the comp window. Depending on how you’ve drawn your AI art, scaling the panels in x and/or y may work better and/or be easier than doing a 3D rotation for the flip.
