Activity Forums VEGAS Pro pan/crop motion has strange “S” curve
  • pan/crop motion has strange “S” curve
    Posted by Rodney Ballard on April 19, 2011 at 2:41 pm
    Hello,
    Using Studio 6. I am attempting to do pan/crop with still photos, but after moving my time line curser, and adjusting the crop box, the motion has a slight ‘s’ curve to it (usually at the very end of the motion). The motion is not linear, from where the pan/crop starts to finish. It’s only a little bit but it sort of bugs me. Any way to take it out?
    Rodney
    Daniel Hughes replied 15 years, 5 months ago 3 Members · 4 Replies
  • Danny Hays
    April 19, 2011 at 5:28 pm
    A linear pan only needs two keyframes. Make sure you don’t have more than that. It’s pretty easy to accidently add them.
  • Daniel Hughes
    April 19, 2011 at 5:33 pm
    If Danny’s suggestion wasn’t the case, check the ‘smoothness’ options. I’ve noticed when I use these there often isn’t linear movement, for some reason.
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
  • Rodney Ballard
    April 19, 2011 at 6:12 pm
    I only have the two key frames, the beginning and the end.
    My smoothness is 1.000, what changes would you suggest I make to it?
    My work-around is to overlap the photos/video 1.29 seconds, put the end key frame very close to the end of the clip, and the ‘s’ curve then happens in the transition between clips and is not very noticable.
    Rodney
  • Daniel Hughes
    April 19, 2011 at 6:28 pm
    I just found the problem. Your point of rotation which is usually found at the centre of the large ‘F’ distorts the motion when not at perfect centre. Make sure it’s in the middle and it’ll be linear.
    Daniel Hughes
    United Kingdom
