Activity Forums VEGAS Pro Pan/crop Jpegs still pictures
  • Pan/crop Jpegs still pictures
    Posted by G. Knight on August 3, 2005 at 7:41 pm
    Another Question,
    When I play a burned DVD some of the(not all)still pictures that I pan across don’t seem very smooth. The pan motion seems to move in wavey chunks. Is this the way it’s supposed to look or is there a solution to have a higher quality pan? thank you for your time, Geoffrey
    Ted Snow replied 21 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Edward Troxel
    August 3, 2005 at 7:55 pm
    Where are you seeing this? On a TV? On a computer monitor?
    If you build the DVD for TV, you can see some of this on a computer because TV’s are interlaced where a computer screen is progressive.
    Edward Troxel
    JETDV Scripts
  • G. Knight
    August 3, 2005 at 7:57 pm
    On the computer The pan looks fine, yet on the TV I get the quality loss.
  • G. Knight
    August 3, 2005 at 8:07 pm
    i’ve done other pans with JPEGS in the past and i haven’t has this problem.
  • Roger Matthews
    August 3, 2005 at 8:56 pm
    I’m not sure if this helps, but try the Smoothness setting in Event Pan/Crop. Putting it at 0 has the program do exactly what you ask in a linear fashion, while a full “1” Smoothness makes the camera do “S-curve” wavy movements as it does its business. It can be subtle, so you might not notice until you see it on a full screen TV.
    I haven’t authored any DVDs with Vegas yet so I can’t help if it’s an authoring issue. I’m crossing my fingers Architect is better than Encore (ick).
  • Edward Troxel
    August 3, 2005 at 8:59 pm
    What preset did you use to render this to MPEG2?
    Could still be an interlace issue. Have you tried adding “Reduce Interlace Flicker”?
    Edward Troxel
    JETDV Scripts
  • G. Knight
    August 3, 2005 at 9:13 pm
    I used NTSC DVD and interlace was used.
  • G. Knight
    August 3, 2005 at 9:14 pm
    I’ll try it and let you know. thanks
  • Ted Snow
    August 4, 2005 at 5:08 am
    One thing you might try also is to render the video using “best” quality. I render ALL photo montages using the “best” setting. It DOES make a difference from my experience.
