Activity Forums VEGAS Pro Pan/Crop feature jumpy
  • Pan/Crop feature jumpy
    Posted by Ron Black on May 29, 2008 at 1:44 am
    When I use the pan/crop and zoom in or out, I don’t often move my mouse correctly and when I get to the final destination desired, the playback shows my every move.
    Is there a way to have the pan or crop simply go from point a to b?
    Mike Kujbida replied 18 years, 3 months ago 3 Members · 3 Replies
  • Terry Esslinger
    May 29, 2008 at 2:40 am
    Place a keyframe at the beginning (start ) of your move. Move the keyframe curser to the end of your scene and place a keyframe. The movement from A (beginning) to B (end) will be smooth (or fast or slow or linear etc depending on your setting. If you are watching it in the preview window and have the setting to high (ie best) it might look kind of funcky depending on the strength of your CPU. Either set the setting to preview (Auto) or do a RAM render to see what iyt will actually look like.
  • Ron Black
    May 29, 2008 at 2:45 am
    I’ve tried that, but if it still follows every little movement I make on the way to point B – maybe too much coffee causes my mouse to do what it does (sometimes I believe it is self-aware).
  • Mike Kujbida
    May 29, 2008 at 10:05 am
    Make sure you’re not accidentally creating extra keyframes.
    As Terry said, there should only be two, one at the start and one at the end.
    If you do see extra ones, right-click them and select Delete.
