Activity Forums Apple Final Cut Pro Legacy Panasonic/Firestore to FCP 1080/25p
  • Panasonic/Firestore to FCP 1080/25p
    Posted by Macka on November 25, 2006 at 2:53 am
    hi,
    new to the panasonic codec/p2. The cinematography team is shooting 1080/25p to be edited on a 25p timeline, using a firestore drive.
    The shooting schedule has shifted, precluding us testing the footage.
    do I just use the DVCPRO 1080/50i sequence settings?
    any issues whan copying from this drive to another to ship to an editor?
    I’m wanting to import directly from files copied from the firestore – has anybody had any issues getting the p2 import option to work with this setup?
    the cine team rang me and they’re using FCP 5.0.1 on a laptop on location and can’t get the clips to import properly to FCP… I’m on 5.0.4 here at the studio – which i believe is better?
    are there any issues or tips? should we upgrade to 5.1 (I’m on a dual core 2.5/5gb ram)- any advantage?
    many, many thanks.
    Izoneguy replied 19 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Izoneguy
    November 25, 2006 at 3:09 am
    Everyone should upgrade to 5.1.2….
    P2 footage import is greatly improved.
  • Macka
    November 25, 2006 at 5:39 am
    thanks – will upgrade before I get the files in that case –
    do you know if importing/ easy setup as 1080i has any negative consequences if editing 1080p originated footage – most documentation is ntsc specific?
    macka
  • Izoneguy
    November 25, 2006 at 5:44 am
    I will check with some 25p footage I have in the morning.
  • Macka
    November 25, 2006 at 10:24 am
    many thanks!
  • Macka
    many thanks!
  • Gary Adcock
    November 25, 2006 at 3:22 pm
    [Macka] “do you know if importing/ easy setup as 1080i has any negative consequences if editing 1080p originated footage – most documentation is ntsc specific?”
    the docs have been updated in the 5.1.2 release notes, and all 1080 material shot in camera is a PROGRESSIVE SEGMENTED FRAME (psf) that always plays back as interlace- so your 25p footage always plays back as 50i.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Izoneguy
    November 25, 2006 at 4:12 pm
    Gary is right….
    The sequence setting for 1080 25p footage is 1080 50i…
    But you can set Field Dominance to none.
