Activity Forums Panasonic Cameras Panasonic Varicam Tape Transport Noise
  • Panasonic Varicam Tape Transport Noise
    Posted by Laurie Case on January 16, 2006 at 12:58 am
    We just started shooting with a brand new panasonic varicam and we are hearing a high pitch noise which sounds like crickets. It sounds like something could be rubbing in the tape transport. Has anyone had this problem?
    Thanks…we’re leaving for a shoot in Switzerland in the morning, so any response ASAP would be great.
    Laurie
    Dpray replied 20 years, 7 months ago 3 Members · 2 Replies
  • John Sharaf
    January 16, 2006 at 2:23 am
    Laurie,
    That’s not right! The Varicam transport is normally one of the quietest I’ve ever seen. You have to look at the tally light or TC reader to confirm that you’re rolling.
    I would definately check with the camera’s owner even if it’s after hours and get a replacement. I doubt that you’ll be able to get it serviced or replaced on location, it’s hard enough to get service from the big factory shop here in LA!
    I have to assume you’ve tried several different cassettes?
    Bottom line, don’t go on a distant location with faulty gear even to such a civilized place as Switzerland!
    Good luck,
    JS
  • Dpray
    January 16, 2006 at 5:45 am
    I agree with the last post– this is not normal, it’s a very quiet camera. Assuming you get that fixed– it’s a fantastic camera. Good luck.
    dpray
