Activity › Forums › Apple Final Cut Pro Legacy › Panasonic TH-42PF11UK Whites are Grey
Jonathan Peyton replied 16 years, 4 months ago 7 Members · 17 Replies
Dave Jenkins
February 2, 2010 at 5:32 pmHi Joe, Straight from Lhe to Component connections.
Dajen Productions, Santa Barbara, CA
MacPro Two 2.8GHz Quad Core – AJA Kona LHe
FCS 3 OS X 10.6 QT 10 -
Dave Jenkins
February 2, 2010 at 5:41 pmHi Jeremy, all the save setting are off including peak limit. The whites look good if it fills part of the screen but if you put full white on the screen it’s shows a grey. Hard to edit a spot that is shot in a white cove and the client keeps asking why the white is grey.
Joe Paolo
February 2, 2010 at 5:43 pmDo you have terminators on the component loop outs? Could try removing them. Most modern gear self-terminates now.
joe
editmojo.com -
Rick Diamond
February 2, 2010 at 9:57 pmThese are all good suggestions, but it appears as if the whites issue is a limitation of this monitor. I have mine hosed in HDMI from an MXO2 and settings are all correct. As Dave said, the whites are OK unless they fill most of the screen.
David Roth weiss
February 3, 2010 at 1:32 am[Rick Diamond] “he whites are OK unless they fill most of the screen.”
Personally, I’d send it back immediately. I’ve never had that issue with any of the previous generations of the Pany Pro monitors.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
