Activity Forums Apple Final Cut Pro Legacy Panasonic sd9 footage
  • Panasonic sd9 footage
    Posted by Jamie Hamlin on July 17, 2009 at 2:11 am
    I cannot import my Panasonic sd9 footage into Imovie or FCP. Im using the log and transfer option in FCP and it pulls up my camera info. All files end with .CPI. Do I need to rename them to get FCP to recognize or what? Been digging for hours on this.
    Jerry Hofmann replied 17 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 18, 2009 at 2:13 pm
    Usually, this just works OK. The footage is AVCHD… and you need to set the preferences in the log and transfer tool to set it to become Pro Res for best results. These prefs are found under the icon that looks like a gear. Might be all you need to do. If you still have problems seeing the footage in the log and transfer window, copy it from the SD card to your hard drive then do the conversion to Pro Res.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
