Activity › Forums › DaVinci Resolve › Panasonic Plasma Monitoring Solution for davinci
Gabriel Bergeron replied 14 years, 2 months ago 17 Members · 52 Replies
Denver Riddle
July 20, 2010 at 9:32 pmI’d be interested in seeing which tests you’re referring to. Without any conclusive test results it’s hard to compare these though they have very similar specs:
The distinction I think you’re missing that separates the pro panny’s from the consumers are the emply card slots, they allow you insert all kinds of terminal boards, from component, hdmi/dvi, HD-SDI to dual link HD-SDI. So if you want 10bit monitoring you’re not going to be able to do that unless the HDMI allows it and previous poster mentioned that davinci doesn’t do 10bit RGB over HDMI.
Illya Laney
July 20, 2010 at 9:49 pmWhere did you read that? Is that just for the pro plasma? The VT25 series can accept 10/12 bit over HDMI. I guess you mean that DaVinci doesn’t do that. The HD-SDI board costs more than the plasma doesn’t it?
Motion Design, Color, Editing
SWGC Incorporated -
Illya Laney
July 20, 2010 at 9:54 pmMaybe a Black Magic or AJA person can answer this if you don’t know. Would an HD-SDI to HDMI converter transmit a 10 bit signal?
SWGC Incorporated -
Rory Hinds
July 20, 2010 at 9:58 pm -
Illya Laney
July 20, 2010 at 10:20 pmI just found that right now. No offense to the BMD guys, but that’s awesome. The HD-SDI pro plasma input costs over 2 grand right?
SWGC Incorporated -
Denver Riddle
July 20, 2010 at 10:32 pmYes unfortunately, more than the plasma itself but you get 10bit RGB 4:4:4 monitoring and resolution support up to 2K. Comparable systems with those specs start at $10,000 and go up. I’d probably try the HDLink first before the Davio. At the start of this thread I was leaning toward doing 10bit HDMI monitoring but now I’m thinking the dual link HD-SDI may in fact be the way to go.
Illya Laney
July 20, 2010 at 10:33 pmThis is a good thread discussing the VT25, G20, Kuro, and 12th/13th generation pro plasmas.
https://www.reduser.net/forum/showthread.php?t=45835
SWGC Incorporated -
Denver Riddle
July 20, 2010 at 10:58 pmIt was Peter Chamberlain, 1/4 down this thread that said:
Currently the HDMI output from Resolve is YUV 10-bit.
RGB 10 bit is available from the DeckLink HD-SDI in dual link and 3G standards.
PeterThat concerns me a little bit if Resolve doesn’t support 10 bit RGB over HDMI, only YUV. My situation is I already own a 42″ 11th generation and now it seems I’m still debating over purchasing dual link HD-SDI or buy a new monitor for about the same price and try my luck with HDMI, it’s good that it seems to do 10 bit but the YUV issue is my only hangup if that is indeed correct. Hopefully I’ll be able to make a decision soon.
Not sure how the AJA Hi5 fits into the scenario, please advise.
Illya Laney
July 20, 2010 at 11:10 pmNo problem. Does the AJA converter make sense now?
SWGC Incorporated
