Activity › Forums › Apple Final Cut Pro Legacy › Panasonic P2 Workflow
  • Panasonic P2 Workflow
    Posted by Matthew Kasey on March 14, 2008 at 4:42 am
    I’m starting a project using P2 HD files which I haven’t worked with before. I was wondering if there’s any pitfalls I should be aware of before I get started. I’m importing everything overnight tonight into FCP (version 5). I used the import Panasonic P2 option and setup an import queue with the interface (not sure what its called) that pops up.
    The footage is all green screen. I was planning on cutting it all in FCP at native res of 1080i 60 and then doing the keying/compositing in AE (probably with a little back and forth between applications). The final product will be a DVD.
    The other question I had is if I should keep it all HD and then just convert if for SD when its time to burn the DVD?
    Or is there some way I should convert it before I even get started?
    Any suggestions would help. The timeline on the project is very tight, so I need to work as efficiently as possible.
    Thanks for any advice/answers to this post.
    Matthew Kasey replied 18 years, 6 months ago 2 Members · 2 Replies
