Activity Forums Panasonic Cameras panasonic p2: Quicktime vs. MXF
  • panasonic p2: Quicktime vs. MXF
    Posted by Dyrectly on May 22, 2007 at 3:10 pm
    Hello. Do MXF files have less compression than the quicktimes and/ or should i back up MXF files or merely the QT files. Thanks!
    Derek
    David S. replied 19 years, 3 months ago 3 Members · 3 Replies
  • Matt Gerard
    May 22, 2007 at 3:42 pm
    When you import into FCP with the P2 import, it is not converting anything, it is just merging data. So, the mxf files will have the same resolution/quality as the quicktimes that are created on import.They have the resolution that was set in the camera when it was shot.
    At least that’s the delusion that i have been operating under…
    Matt
  • Dyrectly
    May 22, 2007 at 6:27 pm
    i guess i’ll just back up the quicktimes from now on… thanks Matt
  • David S.
    May 23, 2007 at 12:53 am
    p2 folders are like tape. I always back them up digitally and optically.
