Activity › Forums › Panasonic Cameras › Panasonic LH1700WP Monitor
  • Panasonic LH1700WP Monitor
    Posted by Nigel Thompson on August 11, 2011 at 2:14 pm
    Hey guys sorry for double posting about a Panasonic monitor here but i didn’t know where else to post it.
    Had to borrow a friends 1700WP LCD the other day and after using it for a few days i saw a 1 pixel blue vertical line come up in the middle of the screen…. All the way down. so i checked multiple sources making sure it was not the kona or the source that was bad … its def.. the monitor.
    Upon further investigation i realized some idiot turned the fan off and didn’t put it back on. so i’m thinking it could be a heat issue since these monitors do run hot.
    Mind you the line disappears when i turn the monitor off for a while and turn it back on…. so def. feel its a heat issue.
    what do you guys think ?
    High End, Production & Post Production
    in the Caribbean
    http://www.bistt.com
    Matthew Romanis replied 15 years, 1 month ago 2 Members · 2 Replies
  • Nigel Thompson
    August 12, 2011 at 6:46 pm
    No Answers i guess
    in the Caribbean
  • Matthew Romanis
    August 15, 2011 at 7:06 am
    Based on the info provided, it sounds feasible.
    Whether it’s heat affecting the panel itself, or just the processing module, needs to be checked out.
