Activity Forums Apple Final Cut Pro Legacy panasonic hvx200 FCP framrate issue
  • panasonic hvx200 FCP framrate issue
    Posted by Dyrectly on February 12, 2007 at 3:39 pm
    So I set the project to 720 24p in easy setup. I did the advanced pulldown in the p2 import from my firestore drive (ver. 2.03 firmware – shot this footage before I upgraded to 3.0). The footage goes directly onto the sequence with no rendering and the sequence is of course 24p – my question is – why is the frame rate in the viewer counting 60? Does it matter?
    Dyrectly replied 19 years, 7 months ago 2 Members · 2 Replies
  • Shane Ross
    February 12, 2007 at 3:56 pm
    Because you initially shot at 60fps, and removed frames (removed the pulldown) when you imported the footage. If you look closely at the numbers, they skip as frames are missing.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Dyrectly
    February 12, 2007 at 3:58 pm
    rock n roll. thank you.
