Activity › Forums › Panasonic Cameras › panasonic HVX200 1080 progressive out of avid
  • panasonic HVX200 1080 progressive out of avid
    Posted by Samuel A. martin on August 1, 2006 at 2:10 pm
    we recorded from panasonic HVX200 a 1080i 25P signal. We have been told by panasonic this is progressive footage, however to import in avid you need to have an interlace project. How do we output progressive footage out of avid from this interlace project? Is the footage actually progressive or interlaced? Do we just output as normal and the footage will come out progressive?
    Regards
    Sam
    Gary Adcock replied 20 years, 2 months ago 3 Members · 2 Replies
  • Noah Kadner
    August 1, 2006 at 3:38 pm
    It is 25p in a 50i compatible stream. There is a section of the HVX200 manual that explains how this works.
    Noah
  • Gary Adcock
    August 1, 2006 at 8:26 pm
    [Samuel A. Martin] “we recorded from panasonic HVX200 a 1080i 25P signal. We have been told by panasonic this is progressive footage, however to import in avid you need to have an interlace project.”
    Search in this forum for information on PSF. (or PsF as it should be called)
    The 1080 format is a progressive segmented frame for all in-camera recordings. Currently only the Stwo, Sony SRW and Panasonic D5 can capture true progressive frames in 1080.
    your avid is correct.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Order my DVD’s are at
    https://www.rastervector.com/dvd/dvd.html
