Activity › Forums › Apple Final Cut Pro Legacy › Panasonic HDC-HS700
  • Panasonic HDC-HS700
    Posted by Daniel Mason on October 19, 2010 at 3:02 pm
    Is anyone using this camera and editing in fcp 6 or express 4.0?
    Panasonic HDC-HS700
    Its format is MPEG-4 AVC/H.264 (AVCHD Standard compliant)
    Just need to see if it actually is compatible before a buy a few of them for college use.
    Danny.
    Paul Dickin replied 15 years, 11 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    October 19, 2010 at 6:08 pm
    It’s compatible. FCP will use the log and transfer window to import the files as ProRes files.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Daniel Mason
    October 19, 2010 at 6:59 pm
    Thanks for a quick response Jerry!
    Danny.
  • Paul Dickin
    October 19, 2010 at 9:56 pm
    Hi
    Its not straightforwardly compatible if the 1080p60 28mbps MPEG-4 mode is used – for that you need something like Clipwrap, not FCP’s L&T. Stick to 17mbps 60i AVCHD mode for compatibility.
