Activity Forums Apple Final Cut Pro Legacy panasonic frame rate converter software not working
  • panasonic frame rate converter software not working
    Posted by Cleditor on September 17, 2006 at 3:07 pm
    i have fcp 5.1.1 and i just loaded a 48fps varicam clip at a capture setting of 720p60 via firewire from the 1200a deck and when i highlight the clip in the browser then select the hd converter from my tools menu, nothing happens. do i have a dead plugin? i downloaded the plugin from the panasonic website.
    thanks,
    c
    Jeremy Garchow replied 20 years ago 3 Members · 3 Replies
  • Shane Ross
    September 17, 2006 at 3:55 pm
    Try putting it in a bin, then doing the conversion. And it that doesn’t work, try opening another project and copying it to that, and then doing the conversion.
    Also, review this tutorial to be sure you are doing things properly:
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=8&page=https://www.creativecow.net/articles/ross_shane/dvpro_hd/index.html
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Cleditor
    September 17, 2006 at 4:56 pm
    shane, you rock. i actually had it in a bin, but i had option clicked the bin to open it as a tab. when i opened the bin by clicking it’s little arrow to reveal it’s contents and then used the frame rate converter, it worked.
    thanks,
    c
  • Jeremy Garchow
    September 17, 2006 at 5:29 pm
    Use the frame rate converter that came with fcp 5.1 install disks and only that plug in.
    Also, your clips should not be in a bin, but in the root level of the browser. I have no idea why that is, but unfortunately that’s how it is.
    Jeremy
