Activity Forums Apple Final Cut Pro Legacy Panasonic BTLH1700W 17 “hot spot”
  • Panasonic BTLH1700W 17 “hot spot”
    Posted by Michael Mk siu on August 28, 2008 at 8:33 pm
    Dear all,
    We recently purchased a Panasonic BTLH1700W 17″ monitor. It is now hooked up to our MacPro through a Matrox MXO.
    We noticed that when a “black screen” is on the monitor, it looks like the monitor has a huge “hot spot”, the image is not even. This is the case when we are sending a black screen through the MXO to the monitor, as well as when nothing’s plugged into it.
    We are wondering if that is the nature of the monitor, or if something’s wrong with our unit. When we are looking at other things – ie color bars / video signal, it doesn’t seem to be affecting the image. And is only visible when a black screen is there – not with other color matte.
    Any help / advice is appreciated.
    Michael
    [ http://www.dvshortfilms.com ]
    [ http://www.mksiu.com ]
    Mitch Ives replied 18 years ago 7 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    August 28, 2008 at 8:56 pm
    [Michael MK Siu] “We are wondering if that is the nature of the monitor,”
    That’s the backlights of the LCD and why people don’t like to use LCDs. There are other manufacturers that overcome this feature but you have to pay more money.
    Jeremy
  • Kent Beeson
    August 28, 2008 at 11:53 pm
    So what would everyone recommend re: a good HD monitor under $3000…one that’s reliable re: color correction…
    K
    web.me.com/kbcv
  • Jeremy Garchow
    August 29, 2008 at 12:11 am
    [Kent Beeson] “So what would everyone recommend re: a good HD monitor under $3000”
    See that’s the problem. The 24″ JVC LCD is very nice in my opinion and so are the TV Logic displays. They are more than 3 grand.
    Your Panasonic is a decent monitor, you just have to watch the blacks. Trust your waveform (that they helpfully put on there).
    Jeremy
  • Walter Biscardi
    August 29, 2008 at 12:15 am
    [Kent Beeson] “So what would everyone recommend re: a good HD monitor under $3000…one that’s reliable re: color correction… “
    TV Logic makes a 17″ that’s actually same panel as Panasonic’s, but they put the ND filter on it so the image is much better and their electronics on the back end are better as well. Other than the Panasonic 1700W, that’s the only other monitor I would recommend.
    I’m holding out until I can afford three of the TV Logic 24″ models. Those run $8k each but are the absolute best LCD grading display I’ve seen for both HD and SD.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Jan Crittenden livingston
    This hot spot is not typical behavior, but would be a result of the LCD being bruised somehow. If you just got this monitor, I would take to a Pansonic Service Center to have it looked at. Possibly best to work this back through the dealer that you purchased it from.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HVX200, DVX100
    Panasonic Broadcast & TV Systems
  • Kent Beeson
    August 29, 2008 at 12:50 am
    Wow 8K for a monitor – oh well, thanks for replies – I know where I can get a 1700W for $1800 (used)…I just hope it doesn’t have the problem of hot spot…
    K
    web.me.com/kbcv
  • Jeremy Garchow
    August 29, 2008 at 12:53 am
    If it’s only when you are sending black to the monitor, then this is proabbly normal. The monitor looks almost very dark purple when you send nothing but black, right? Does it look like the flouescent tubes showing through?
    (Sorry Jan, this monitor does this, I found out during a night shoot).
  • Walter Biscardi
    August 29, 2008 at 12:55 am
    [Kent Beeson] “Wow 8K for a monitor – oh well, thanks for replies – I know where I can get a 1700W for $1800 (used)…I just hope it doesn’t have the problem of hot spot… “
    The 1700W is less than $3k new. That’s why I mentioned it.
    Read my Blog!
  • Michael Mk siu
    August 29, 2008 at 10:33 am
    Thank you everyone for their input and advice.
    And Jan, seeing how this unit is shy of a week old, and the hot spot was apparent the first time we turned it on, we’ll bring it back to our dealer and have it checked out.
    Thank you again.
    Michael
  • Gary Adcock
    August 29, 2008 at 12:26 pm
    [Kent Beeson] “Wow 8K for a monitor – oh well, thanks for replies “
    Sorry but $8K is nothing for a “true color” reference monitor
    Take a look at a grading displays from CineTal or E-Cinema that start at nearly 2x that, and are the standard for onset color monitoring in hollywood.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
