Activity › Forums › Apple Final Cut Pro Legacy › Panasonic BT-LH2600W Hi pitch Noise
Posted by Ed Stevens on October 2, 2006 at 9:56 pmI just bought the panansonic BT LH2600W and now noticed a high pitch hum coming from it. Removed all inputs and still the same. Anyone else have this problem?
Christopher Stewart replied 16 years, 2 months ago 6 Members · 6 Replies -
Jerry Hofmann
October 3, 2006 at 3:18 amThe one I’m around sure’s quiet… maybe you should have it looked at?
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Michael Alberts
October 3, 2006 at 3:43 amThe fan is on by default. The manaul doesn’t specify under what conditions you would want the fan on or off. I’ve always kept mine off on the LH1700, and I’ve turned off the fan on my new LH2600.
Michael Alberts
Ambidextrous Productions, Inc. -
Parke Gregg
January 29, 2008 at 5:07 amI just installed my LH2600W and it has the same high pitched hum/whine. It’s not the fan, or at least it’s not the normal fan noise. ED, were you able to fix this, or get your monitor replaced?
(I know… I’m digging up posts from way past…)
-Parke
Christopher Stewart
May 28, 2008 at 12:37 amDid you ever get this resolved?
I’ve got a LH1700WE and find it near unusable. It’s been sent back to Panasonic once already and has just came back even louder and “whinier” than before.
Russell
July 5, 2010 at 1:38 pmHello Christopher,
This is an old post but did you ever come to a solution for this problem?… I have this same unit doing the same thing.
Did Panasonic fix it and how much if it was out of warranty?
Thanks.
Russell
Christopher Stewart
July 5, 2010 at 7:37 pmYes, it was sorted after I spoke to Panasonic (Canada) directly. It was something to do with the power system I believe. In any case, they fixed it under warranty, though it took a few weeks for the parts to come from Japan.
