Activity › Forums › Event Videographers › Panasonic AG-HMC40 or HC-VX870 (HD prosumer vs 4K consumer)
  • Panasonic AG-HMC40 or HC-VX870 (HD prosumer vs 4K consumer)
    Posted by Kyle Walker on May 18, 2015 at 7:14 pm
    I’m trying to upgrade the old mini-dv gear I use for long-form shoots (i.e. concerts, lectures, etc). I’m also trying to keep it under $1000
    Would one recommend a brand new HC VX870, which is apparently one of the least expensive 4K cameras on the market right now. Or would one recommend a gently used HMC40 for $850 on Craigslist.
    I’m not sure if it’s smarter to go with a more consumer grade camera but have one that may be sustainable quality for longer, or one suitable for more prosumer grade setups but been out for a few years.
    Most of what I do for these types of shoots is throw the camera on a tripod and press record. I have external audio gear I set up as well.
    I must admit that larger form cameras (prosumer, professional) are what I would ideally like to be seen with for professional reasons in regards to how people take one more seriously with larger gear. Though I know that sounds somewhat unreasonable. But I can’t dismiss that that is a factor.
    Any advice appreciated!
    Bill Bruner replied 11 years, 4 months ago 2 Members · 1 Reply
  • Bill Bruner
    May 20, 2015 at 2:28 pm
    Hi Kyle – sadly, the HMC40 will produce relatively low resolution images by modern standards.
    I would choose the VX870 (or the $998 4K Sony AX33, which has a viewfinder) over the HMC40.
    Here is what the AX33 can do:
    https://vimeo.com/120943700
    https://youtu.be/spbNiBRcUrY (please watch at 2160p and your monitor’s highest resolution)
    If you want a consumer camcorder to look more “professional”, all you need is a square lens hood or a $50 matte box.
    Here is a picture of my Panasonic TM900 consumer camcorder with a pro mic and a matte box.
    Here it is with the matte box, an LCD hood and a consumer mic.
    Hope this is helpful and good luck with your upgrade!
    Bill
    Hybrid Camera Revolution
