Activity Forums VEGAS Pro Pan-Crop series of “stills”
  • Pan-Crop series of “stills”
    Posted by John Gregoriades on August 3, 2010 at 5:35 am
    Hi again,
    I have a “flashing sign” created by two stills: One “bright,” one “dull”. I set a series of about 20 of these stills, alternating, each one second long, and it works well.
    But I would also like to zoom-in, as I go through this series. Each “still” has its own pan-crop control, but how can I connect them all up, end-to-end, and then have a single control to effect a smooth zoom, while progressing through the entire series?
    Thank you.
    John
    John Gregoriades replied 16 years, 1 month ago 4 Members · 4 Replies
  • Aleksey Tarasov
    August 3, 2010 at 8:20 am
    Save all stills as a separate Vegas project and nest it (insert this project to the timeline like any other video clip) to the main project.
  • Graham Bernard
    August 3, 2010 at 8:59 am
    . . or . . use track motion.
    Grazie
  • Carlton Rahmani
    August 3, 2010 at 11:46 am
    Turn the track(s) that your stills are on into a composite child whose parent track has nothing else on it. Then do motion tracking on the (otherwise empty) parent track to get the zoom in/out, etc. effect you’re looking for.
    Let me know how this works out.
  • John Gregoriades
    August 3, 2010 at 8:32 pm
    Thank you all very much. The simplest suggestion, which I tried and it worked, was to pre-render the sequence. The other methods I simply haven’t much experience with. Certainly the parent-child concept I have never focused on, and it is bound to be a very useful tool as well. Is there perhaps a YouTube video on it?
    Regardless, Many thanks!
    John
    John23GR
