PAL/NTSC ???
I have a job which needs to end up two formats. PAL and NTSC. Everything has been designed at 768×576 in Photoshop. Therefore my final output comps are 768×576. 30 fps square pixels.
I need to end up with a PAL file and a NTSC file. The end destination is a DVD of highest quality.
I really am not even sure what to ask. Can I use the 768×576 comp and get everything I need? What about frame rate? Do I need to fit to fill? Crop?
If you need more info please let me know and thankyou for your help.
I’m only half the thing I say I am, the other half are me.
