Activity Forums Adobe After Effects Palette Mapper for Adobe After Effects v1.0 officially released – 100% FREE.
  • Palette Mapper for Adobe After Effects v1.0 officially released – 100% FREE.
    Posted by Richard Rosenman on June 2, 2020 at 4:50 pm
    Hi gang;
    I’ve just published my free plugin for Adobe After Effects, called Palette Mapper. It is 100% free! Here’s some info about it:
    I’m pleased to announce the immediate availability of Palette Mapper for Adobe After Effects.
    Palette Mapper is an exciting plugin for Adobe After Effects that extracts the color palette from a video sequence on a frame-by-frame basis and maps it horizontally into an image using vertical lines. Palette Mapper can be used as a creative application to produce beautiful imagery, or as an analytical tool for the study of color grading in film, video and animation.
    Mad Max: Fury Road (2015)
    Palette Mapper works by scanning each frame of the footage, analyzing all the pixel values to extrapolate an averaged frame color, and mapping them into a set of sequential vertical lines. The result is an image showcasing the changes in tone and luminance throughout the entire length of a sequence. Although there are various tools available to achieve a similar effect, it’s always been through a complex and time consuming process, often hindered by technical limitations.
    Monsters, Inc. (2001)
    From creative backgrounds to film analysis, Palette Mapper is a must-have plugin for artists, videographers and designers alike. For more info, check out the Palette Mapper Product Page!
    Eric Santiago replied 6 years, 3 months ago 3 Members · 5 Replies
  • Richard Garabedain
    June 3, 2020 at 10:02 pm
    Ive seen this idea done with the average temerature of the day for a year…but its for video…
  • Eric Santiago
    June 4, 2020 at 1:39 am
    Maybe off-topic but what’s the name of that effect that does the directional color smear?
    That was up there with lens flare as far as overused effects 🙂
    June 4, 2020 at 3:39 pm
    i believe the technique your talking about invovles adding a mosaic and then stretching
  • Richard Rosenman
    June 4, 2020 at 3:45 pm
    That sounds pretty cool. I’d love to check it out – got a link?
    -Rich
  • Eric Santiago
    June 4, 2020 at 6:06 pm
    [Richard Garabedain] “i believe the technique your talking about invovles adding a mosaic and then stretching”
    I am not sure if that is it.
    I know that it smears the one pixel dependent on a direction to infinity.
    I can mimic this by duplicating the layer and masking a thin portion and scale to an extreme amount.
    You have to place the anchor in the right spot to achieve it though.
    There as a plug-in and now its defunct many moons ago.
    Basically stopped working on newer versions of CC.
