Activity › Forums › Apple Final Cut Pro Legacy › PAL to NTSC workflow for FEATURE
  • PAL to NTSC workflow for FEATURE
    Posted by Jim Blokland on January 14, 2006 at 3:07 am
    Hello:
    I’m cutting an indie feature, shot partially on a DVX100 at 24P normal, and on a PAL camera at 25i. Wondering what the best post route is, to prepare for a filmout. Is there such a thing as a SLOW PAL transfer that can de-interlace the PAL footage and get it to 24P NTSC so I can just cut at 24P? I’ve heard that the Symphony can do some sort of transfer, but I’ve not had experience with that personally. Any insight as to a workflow is welcome. (also, if anyone can recommend AXP vs. FCP for this type of job, I’d appreciate it)
    Best, JIM.
    OSX.4.3
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.2 TB RAID
    AVID XPRESS PRO/MOJO
    Gunleik Groven replied 20 years, 8 months ago 3 Members · 2 Replies
  • Graeme Nattress
    January 14, 2006 at 12:47 pm
    For PAL 50i to 24p in FCP, it’s quite easy. Bring in your PAL footage as normal. Apply a de-interlace filter render, change seq dimensions to NTSC, use motion tab to scale video to fit, output to a file. Take that file to Cinema Tools, ask it nicely to “conform” to 24p and you’re done.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Gunleik Groven
    January 14, 2006 at 5:11 pm
    [Graeme Nattress] “Bring in your PAL footage as normal. Apply a de-interlace filter render, change seq dimensions to NTSC, use motion tab to scale video to fit, output to a file. Take that file to Cinema Tools, ask it nicely to “conform” to 24p and you’re done.”
    Hi Graeme!
    Is this better than your “Standards Conversion” route?
    Or the Compressor (“Shake’ish”) conversion route?
    Gunleik
