Activity Forums Apple Final Cut Pro Legacy PAL to NTSC Audio Conversions
  • PAL to NTSC Audio Conversions
    Posted by Dave Gutt on July 22, 2009 at 3:10 pm
    Howdy all-
    I’ve got some audio that was created for both a PAL and NTSC animated program. The program is the same, it just got flipped.
    Somewhere during the process a series of the NTSC mixes were lost, yet I still have the PAL versions. These are shorter in duration than their NTSC brothers due to the frame drop.
    Can anyone recommend a way for me to adjust the PAL versions to marry with the NTSC versions?
    Thanks very much!
    Michael Gissing replied 17 years, 2 months ago 3 Members · 2 Replies
  • John Pale
    July 22, 2009 at 10:26 pm
    Try using the time stretch function in Soundtrack Pro to match the duration.
    Normally there should not be a duration difference. How was you conversion done?
  • Michael Gissing
    July 22, 2009 at 11:00 pm
    If you are talking about a 24 to 25 frame speed up, that is 4%. If it is 23.98 to 25 it is a bit trickier.In theory it is 4.1% but on a long form show the sync will drift as you need to calculate to about 4 decimal points to be totally accurate (4.106 is a quick calculator estimate). I had to correct a two hour telemovie a few years ago and I needed to trim to 5 or 6 decimals to get perfect sync. It was a bit trial and error and I wish I had written the number down.
    To correct pitch I only recommend MPEX3 or Pitch N Time.
