Activity Forums Apple Final Cut Pro Legacy pal to HD??? please someone!!!
  • pal to HD??? please someone!!!
    Posted by Paulo Marques on October 17, 2010 at 8:42 pm
    i have a footage of a movie in pal 720 × 576 MPEG-2 Video and i would like to get in my project that is 1280x 720 hd, but when i preview the footage the images looks rispid and awful??
    (i resize the movie pal in final cut pro to match my canvas)
    someone please tell me what am i doing wrong
    Thank you very much
    Andreas Karoliussen replied 15 years, 5 months ago 3 Members · 4 Replies
  • Andreas Karoliussen
    October 18, 2010 at 6:24 am
    Compressor does quite a good job upconverting, if you turn frame controls on and tweaks it a bit.
    Do a few tests on your own.
    Some combinations gave me a white frame…
    there are many tutorials out there:
    https://www.digitaljuice.com/community_forums/tm.asp?m=26143
    https://discussions.apple.com/thread.jspa?threadID=1229639
    https://www.pistolerapost2.com/shaneross/DV_to_DVCPRO_HD.mov
    Good Luck!
  • Michael Gissing
    October 18, 2010 at 7:06 am
    MPEG2 is often full of compression artifacts which just get worse when you blow the frame up. FCP doesn’t scale as nicely as Compressor so you will get a small gain with that but the limiting factor is the source material.
    I sometimes use Video Purifier to clean and scale up, but it is always a trade off between MPEG artifacts and softening or smearing the picture. Pigs ear to silk purse is still a dream
  • Paulo Marques
    October 18, 2010 at 11:46 am
    hi!!
    i use compressor, but the images of the footages are very crispy and looking rasgo and crispy… how can i get rid of this?
    April 13, 2011 at 8:48 am
    What settings did you use in Compressor?
    Try anti aliasing off and detail level @ 30 or 40
    With progressiv output.
    detail at 100 gives a hard image…
    Andreas
