Activity › Forums › Apple Final Cut Pro Legacy › PAL Resolution, Frame rate and slo mo, interlaced or progressive?
Posted by Bret Goldsworthy on October 29, 2007 at 9:41 amI am shooting a shot for a TV commercial of a basketball player slam-dunking. I’d like to do a really good speed play and slo mo. I
Arnie Schlissel replied 18 years, 11 months ago 4 Members · 3 Replies -
Adam Taylor
October 29, 2007 at 10:31 am“I’m told the TV station broadcasts PAL 1080i. @ 25 FPS. One last question, (to retain quality) what is the best way to deliver to the station?”….
the only safe answer is ASK THEM!!
Not all stations transmit in HD yet, so the best thing you could do is contact the Transmission dept and ask their advice.
adam
Editor/Mixer
Character Options Ltd
Oldham, UK -
Rafael Amador
October 29, 2007 at 11:31 am[icedogg] ” the TV station broadcasts PAL 1080i. @ 25 FPS”
This do not exist. PAL is 720×576. Ask the broadcasters for the specs.
About making slow mo you will get a more smooth effect with a 50i than with a 25p because you start with the double of pictures.
rafael -
Arnie Schlissel
October 29, 2007 at 4:14 pmThe camera supports 1080P50 and 1080P60. You’ll get your best slow-mo by setting it to one of those settings, and then using Cinema Tools or some other method to give you a frame-to-frame change to 25fps.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog
