Activity › Forums › Apple Final Cut Pro Legacy › Pal Project Exported to NTSC missing final 2 seconds of footage
  • Pal Project Exported to NTSC missing final 2 seconds of footage
    Posted by James Mulryan on June 30, 2006 at 9:29 pm
    I am editing a 45 second commercial imported into FCP using DVPAL Easy Setup. When I export this project from the timeline using DV NTSC out, the project falls out of sync. When I export the project as a DV PAL quicktime it plays perfectly in a PAL timeline. I then reexport it from this new timeline using DV NTSC settings making the movie self contained. I then drag it back into an NTSC timeline and it plays back in sync, but the last 2 seconds of the commercial are missing. Does anyone know what I am doing wrong?
    DVD Pal footage imported into FCP using DVDxDV
    FCP 4.5
    OS 10.3.9
    Dual 1G G4
    QT 7.1
    Stephen95 replied 20 years, 3 months ago 3 Members · 2 Replies
  • Rennie Klymyk
    June 30, 2006 at 9:44 pm
    I don’t have any answers but this kinda reminds me of linear tape transfers. When going to pal from ntsc you need a longer tape. A 1 hour program required a 1’5″ tape for the conversion. Can you add some black to the end and trim it in ntsc land?
    “everything is broken”
  • Stephen95
    June 30, 2006 at 11:23 pm
    This may not be of any help. But this plug-in has saved my life on a couple of occasions. Check out the
