Activity Forums Apple Final Cut Pro Legacy PAL media converted by fcp into NTSC sequence
  • Ben Holmes
    March 7, 2008 at 11:34 pm
    John
    You can use compressor to do a standards conversion, or use the excellent Nattress plug-in. Doing what you suggest will not fix the differences in frame rate, and may cause scaling issues due to the different number of lines.
    Ben
  • Jon Wetterau
    March 9, 2008 at 7:37 pm
    Are you suggesting that I should go back and convert my PAL media to NTSC, then relink it to the stuff in my project timeline? Or are you saying I can export what I have for conversion?
