Activity Forums Adobe After Effects PAL graphic sawtoothed into NTSC AE project
  • PAL graphic sawtoothed into NTSC AE project
    Posted by Brian Dugan on May 27, 2008 at 5:41 pm
    Hey, I have a stock video/animation that is PAL 720 x 540 25fps which looks great when I play in directly in Quicktime. However when I put it into AE it becomes sawtoothed edged, also when I render it out same thing. Even at 100%. What can I do?
    Thanks, Brian
    Kevin Camp replied 18 years, 3 months ago 2 Members · 1 Reply
  • Kevin Camp
    May 27, 2008 at 10:18 pm
    it may be that ae is misinterpreting whether the footage is interlaced or progressive. if you know which it is you can see if ae is interpreting it correctly. select the footage in the project window. then choose file>interpret footage>main… check the ‘separate fields’ option to see if it has the correct interpretation (lower, upper or none). if you don’t know the correct interpretation, pick one and see if it makes any difference.
    also make sure that the pixel aspect ratio is correct too, that will make a difference when you convert from pal or square pixel to ntsc.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
