Activity Forums Adobe Encore DVD PAL Encore project to NTSC
  • PAL Encore project to NTSC
    Posted by Martin Banks on July 14, 2005 at 4:26 pm
    Hello,
    I have a video project that was filmed in PAL and put onto DVD using Encore as a PAL project too. Now I want to send some copies to the states which require an NTSC. I was someone would be able to suggest the best way to make an NTSC project? Any help is greatly appreciated!
    Martin.
    Terry M replied 21 years, 1 month ago 2 Members · 1 Reply
  • Terry M
    July 20, 2005 at 3:10 pm
    Just had exactly the same issue arise and discussed with various people. Seems that it is just possible that a PAL DVD might play in the USA. However I have opted for making an NTSC version of my DVD as follows:
    I opened a new project, selecting NTSC format. Next I copied as menu assets all the original menus from the PAL project. I then used Canopus Procoder to convert all my PAL avi to NTSC versions (including the avis used in the motion menus).
    I reopened the PAL project and noted down the time for each chapter point in the timeline, and the name I’d given it. Next, opening the NTSC timeline I added chapter points – it is esay in the project window to type in the required timecode to shift each chapter point to its correct location.
    Finally I linked each menu button as before.
    If it sounds a little time-consuming and a pain, it was! However the NTSC DVD plays fine.
