Activity Forums Adobe Encore DVD PAL DVD; only lower field first option
  • PAL DVD; only lower field first option
    Posted by David Gray on June 15, 2015 at 4:00 pm
    Good Afternoon All,
    Working on a DVD for the first time in a while and I’m trying to create a PAL DVD which I believe should be upper field first?
    Encore only offers an option for lower field first.
    When burning the DVD there are interlacing artifacts. They could be to do with the original interpretation.
    Unfortunately, I do not have access to the source project right now. Only an MPEG-2 which is lower field first.
    I should do as of tomorrow.
    I’m naturally concerned that encore only seems to offer lower field first and this could be the root of the problem.
    Your help and thoughts are much appreciated!
    Jeff Pulera replied 11 years, 3 months ago 2 Members · 1 Reply
  • Jeff Pulera
    June 15, 2015 at 5:49 pm
    Hi David,
    I understand you have no access to the source video/project right now, but I believe that when you export from Premiere to “MPEG-2 DVD”, if you choose Upper Field at that point and encode UFF, then Import that into Encore, Encore will not transcode and will keep the UFF setting.
    Not sure about setting up Encore to manually transcode source you have now.
    Jeff Pulera
    Safe Harbor Computers
