Activity › Forums › DVD Authoring › PAL DVD from a NTSC FCP/DVDSP project.
  • PAL DVD from a NTSC FCP/DVDSP project.
    Posted by Andy Levine on December 17, 2007 at 5:54 pm
    i need to produce a pal dvd for a client from a ntsc FCP/DVDSP project.
    first guess was just flip the switch in the dvdsp disc inspector… reimport assets and go… doesn’t work. my audio is good but .mp2 files are ‘not compatible’. i think i have to recompress but, to what standard? is pal dvd not .mp2? what compressor setting is correct? DV PAL? is that a DVD compression?
    thanks in advance for your help.
    -andy
    Bill Stephan replied 18 years, 9 months ago 2 Members · 3 Replies
  • Bill Stephan
    December 18, 2007 at 6:41 pm
    You need to convert your video to PAL and then encode it as PAL MPEG-2. You cannot change the disc type to PAL and then use NTSC assets. The frame rate and frame size won’t work.
    FWIW approximately 75% of DVD players and television sets in the PAL world can play an NTSC DVD. A small percentage of that number will display the picture as black & white.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Andy Levine
    December 19, 2007 at 2:28 pm
    OK, so i use compressor. i select mpeg2 and switch NTSC value to PAL. what audio setting should i use? in a quick test, the audio track ends up a little but longer than video.
    also, how can i test this disc if at all? i need a PAL system, right?
    thanks for your help.
  • Bill Stephan
    December 19, 2007 at 4:59 pm
    I’m not sure that compressor will do a standards conversion, but you can try it and see how far you get. Some people use after effects or various software plug-ins.
    Easiest way to check a PAL DVD is to get one of those $39 Cyberhome DVD players that Best Buy sells. It will play a PAL DVD into an NTSC TV (it actually does a standards conversion in the player).
    Bill Stephan
    USA Studios
    New York City
