Activity Forums Apple Final Cut Pro Legacy pal avi to ntsc
  • Jerry Hofmann
    November 8, 2005 at 1:00 am
    Open the files in QuickTime Pro, and export them as QT movies using the same pixel count for the frame size that the AVI files had. Then edit the QT movies.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Dekkoman
    November 8, 2005 at 3:16 am
    If the AVI won’t playback in QT, check out this page for some further advice:
    https://www.macos.utah.edu/Documentation/OSX_AVI_Solutions1/OSX_AVISolutionsCODECs.html
    I’ve been struggling with the reverse – NTSC to PAL.
    After converting in QT to .mov, it will playback in FCP, but mine was jerky due to it still being NTSC in a PAL timeline. You might use one of the many filters out there for FCP to convert standards.
    Tim Webster
  • Rbfineline
    November 8, 2005 at 11:40 pm
    I tried that- plays nice in quicktime, plays real jerky in FCP.
