Activity › Forums › Apple Final Cut Pro Legacy › PAL aspect ratio 720 x 576 NOT 768 x 576
  • PAL aspect ratio 720 x 576 NOT 768 x 576
    Posted by Stephen Sarsfield on August 3, 2009 at 4:23 pm
    I lookd on the forum but could not find any info on this subject. Help!
    I am trying to create a PAL 720 x 576 through Export>Quick time conversion. the settings tab has a 4×3 option 720 x 576 (768 x 576)
    Unfortunately it made the latter (in quotes)
    How can i produce a 720 x 576? Thanks!
    Jeremy Garchow replied 17 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 3, 2009 at 4:36 pm
    That’s just Quicktime strethcing it out to make a square pixel image for viewing on your computer.
    TO make a real PAL version from NTSC, you should check out plug ins such as Nattress Standards Converter, or if you don’t want to spend money, try compressor. QT conversion is no good.
    Jeremy
