Activity Forums Adobe Premiere Pro PAL and / or NTSC
  • PAL and / or NTSC
    Posted by Daniel Kenyon on August 29, 2011 at 3:13 pm
    Hi
    I’m aware of the regional uses of both these formats but there’s something i’d like to ask.
    Is it noticeable if both formats are used in the same project? ie If I set up a PAL project and used a clip which was filmed on the NTSC setting on my camera would it be obvious or is it ok to do?
    The reason I ask is that I own a Canon 60D (UK) which has a maximum PAL frame rate of 50fps. However on the NTSC setting it’s 60fps, which obviously enables better quality slow motion footage.
    No I know it may make sense to do the whole project in NTSC, and that’s something else i’d like to ask. Is it ok to do this if my accepted format, in the UK, is PAL?
    Sorry if these are stupid questions but i’d just like to clear it up.
    Daniel
    Vince Becquiot replied 15 years ago 2 Members · 3 Replies
  • Vince Becquiot
    August 29, 2011 at 3:24 pm
    Hi Daniel,
    Yes, it is noticeable, and the more motion you have, the worse it gets. You will get an obvious jitter or blur, depending on whether you choose to add frames or blend as your export settings.
    The bottom line is avoid frame conversion as much as possible. There are tools that can provide the conversion like Twixtor, or plugin from Videocopilot, but they demand long render times and the results aren’t near perfect.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Daniel Kenyon
    August 29, 2011 at 3:48 pm
    Thanks Vince
    So would suggest that I leave the NTSC settings alone on my camera and just stick to PAL?
  • Vince Becquiot
    August 29, 2011 at 4:05 pm
    Hi Daniel,
    Yes, although experimenting is almost never a bad thing 🙂
    Vince Becquiot
    Kaptis Studios
