Activity Forums Adobe After Effects painting with dots/bubbles of color
  • painting with dots/bubbles of color
    Posted by Jonas Espinoza on March 12, 2006 at 11:22 pm
    ive seen this done on a few spots, where a path (3d sometimes) is stroked with dots that grow randomly as the stroke end moves along. anyone seen this? could it be something with particular set up with dots and to randomize the color?
    Alon_a replied 20 years, 6 months ago 2 Members · 1 Reply
  • Alon_a
    March 12, 2006 at 11:37 pm
    I’m not sure what’s the exact look you’re after, but what you describe is indeed possible with Trapcode Particular. Set the emitter velocity to 0, set the rate to something appropriate according to the speed the emitter moves and the desired density of the dots, and give the particles a long lifespan with the necessary color and size over life.
    – Alon
