Activity Forums Apple Final Cut Pro Legacy Paint Shows Through Video
  • Paint Shows Through Video
    Posted by Collin Alexander on January 9, 2008 at 5:08 am
    I’m having a problem with Motion, no response on the Motion forum, maybe someone can answer this. It would take about 30 seconds for someone to confirm or deny this bug.
    In Motion.
    1. Place a video into the comp.
    2. Select new camera.
    3. Make 3D
    4. Rotate the view so that you can see behind the video.
    5. Use the paint brush and paint a scribble.
    6. Move the scribble in 3 dimensions so that it is clearly behind the video.
    7. Rotate the view so that the video covers up the scribble.
    8. Make sure the opacity of the video is 100%.
    9. Make sure the opacity of the layer is 100%, and blend modes are all “normal”.
    Can you see the scribble through the video?
    I do, and it doesn’t make any sense to me.
    Please, I beg anyone. Please tell me if you repeat this problem, or if it is just me.
    Thank you.
    Collin Alexander replied 18 years, 8 months ago 3 Members · 6 Replies
  • Anonymous
    January 9, 2008 at 1:25 pm
    Hi there,
    Just had a quick play in Motion to try and replicate this….and I’m afraid I could not.
    I’m running Motion 3.0.2
    Just dumped a .mov in, added a camera and scribbled behind it – and I can’t see the scribble through the video…
    Sorry!
  • Collin Alexander
    January 9, 2008 at 4:26 pm
    Thanks for doing it. This is making me completely crazy.
    My opacity is set to 100%. Blend modes are normal.
    If anyone has any idea why I see paint and particle emitters through a video, please let me know.
  • Jeremy Garchow
    January 9, 2008 at 4:51 pm
    What format is your video?
  • Collin Alexander
    January 9, 2008 at 10:58 pm
    DV
  • Jeremy Garchow
    January 10, 2008 at 4:53 am
    What I was thinking is that the video had an alpha. You didn’t export from FCP as something other than dv did you by any chance?
    Jeremy
  • Collin Alexander
    January 12, 2008 at 8:46 pm
    No alpha channel. It’s a bug in the software I fear. Here are two examples, the only difference being layer order.
