Activity Forums Adobe After Effects Paint Drip Bumps
  • Paint Drip Bumps
    Posted by Kuljeet Singh on February 10, 2016 at 5:26 am
    hi,
    i’m trying to make Paint drip transition, so that in the end paint covers all the screen. I used CC mercury on solid layer to create this effect, but cant achieve what i want to achieve.
    Please help me how to get bumps & reflections only on the edges.
    Please see the attached image for the Reference.
    Chris Bobotis replied 10 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Tudor “ted” jelescu
    February 10, 2016 at 7:21 am
    FreeForm Pro can be used to achieve this effect. You can displace your animated paint layer in 3D space. This will enable you to use Lights and have control over the texture of the paint, also you can use a rflection map for more realism. To create a displacement map you can comp a duplicate of your animated paint layer over black, use a Hue/Saturation effect to crush all color to white and a Matte Choker to feather the edge – you may need to add a soft blur as well. Precomp and use as a displacement map in the FF Pro plugin- this will give you the bevel you need for the paint layer.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kuljeet Singh
    February 10, 2016 at 10:48 am
    Many thanks,
    i’m new to AE, i will try your method & respond after it.
  • John Cuevas
    February 10, 2016 at 2:22 pm
    You might want to experiment with the Glue Gun effect.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Michael Szalapski
    February 10, 2016 at 6:27 pm
    You might try messing with CC Glass on top of your drips.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kuljeet Singh
    February 12, 2016 at 7:51 am
    many thanks to all for the help.
    1. i’ve tried free form pro, but it gives open Gl Command error.
    2. then i created reflection map as TED said, used it in “CC Glass” bump map, which created random bumps on my paint compo.
    Overall it improved the looks. But bumps are random, i only want them on edges, is there any way around.
    Many Thanks
    February 12, 2016 at 12:44 pm
    Chris Bobotis from Mettle can help you with the FF Pro issue- contact them through their website or here on the COW on the plugin forum.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Bobotis
    February 12, 2016 at 2:18 pm
    This effect is very doable in “FreeForm” + “FreeForm Pro” – adding CC Glas on top of that is a good idea.
    An openGL error probably means that your GPU does not qualify to run “FreeForm Pro”. Try “FreeForm V2” on the same system… you will not get this error.
    Or, use FreeForm Pro on a system with a qualified GPU (Display Card).
    Cheers,
    Chris
    mettle.com
