Activity Forums Maxon Cinema 4D Page turn animation with sweep nurb, front back texture problem
  • Page turn animation with sweep nurb, front back texture problem
    Posted by Jake Nelson-dooley on October 11, 2011 at 3:26 pm
    TL;DR – Front/back textures almost work (with the help of stick texture tag) but get swapped at one point during the animation.
    I built a page turn animation using a bend deformer similar to what Mike Senften describes at one point here https://greyscalegorilla.com/blog/2011/01/how-to-animate-a-page-turn-with-cinema-4d-and-planesmart-with-mike-the-monkey/
    Instead of using a flat plane, I used a sweep nurb with two bezier splines to create a page with some lift near the binding (basically I swept a hill-shaped spline along a linear spline, which yields a nice looking page). Then I used PLA to invert the hill-shaped spline as the bend deformer comes across and the page turns. This is when the texture problem occurs.
    The front face’s texture starts out on the front and the back on the back. Halfway through the page turn, they get switched around. Could it be that when I change the shape of the hill-shaped spline from convex to concave, that C4D is somehow reassigning the front/back faces?
    Brian Jones replied 14 years, 11 months ago 2 Members · 5 Replies
  • Brian Jones
    October 11, 2011 at 5:04 pm
    can you post the scene file?
  • Jake Nelson-dooley
    October 11, 2011 at 5:43 pm
    here it is: 3060_pageturn.zip
    Thanks for looking,
    Jake
  • Brian Jones
    October 11, 2011 at 10:46 pm
    yeah it looks like as long as it’s a sweep the sides can change dynamically. If I make the pages editable it works as expected, whether that’s a problem or not depends on why you used a sweepnurb and if you are doing stuff that needs that later.
    October 12, 2011 at 1:47 pm
    Gotcha. Yeah, I’m working around the problem by keyframing the material’s side property. The sweep nurb is nice to have b/c I can change the curl of the page. Thanks for checking it out!
    -Jake
  • Brian Jones
    October 12, 2011 at 7:42 pm
    I was trying Flat mapping and was having limited success there as well, it was ok in the curl part but more of a problem once it flipped over. You could also use a second deformer for the curl (maybe an FFD would work).
