Activity › Forums › Apple Final Cut Pro Legacy › page peel works on a graphic out but not in
Posted by Andrew Dieringer on February 26, 2009 at 7:41 pmpage peel works on my graphic out but not in. Is there a workaround? thanks,
adTom Wolsky replied 17 years, 6 months ago 3 Members · 6 Replies -
Tom Wolsky
February 26, 2009 at 8:48 pmWorks for me. You might want to provide more information.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Bret Williams
February 26, 2009 at 11:24 pmIf you’re applying a peel away to the beginning of a graphic, and the graphic sits alone on it’s own track, then what you’re seeing is NOTHING peel away to your graphic. Is that what’s happening? Try reversing.
Andrew Dieringer
February 27, 2009 at 4:01 amso a page peel is ONLY AWAY? Any quick tips for a peel ON?
Andrew Dieringer
March 2, 2009 at 6:06 pmno reverse check box, however there is a “peel” check box which seems a little ridiculous to me…why would you use a peel transition without the peel? hmm…
Tom Wolsky
March 2, 2009 at 6:19 pmWithout the peel you get a curl.
There is a little arrow button on the mid right side of the controls. That’s the reverse button. Explained in the manual and searchable PDF. IIIp396 has graphic that calls it out.
All the best,
Tom
