Activity Forums Apple Final Cut Pro Legacy Page Peel ,problem
  • Page Peel ,problem
    Posted by Bruce Lambert on October 10, 2008 at 1:57 am
    I am using the page peel effect between two layers. If I print to tape out of the timeline the effect plays fine. If I export to a self contained Quicktime movie when I play the movie back the effect cuts to the layer I am going to and I only see the shadow of the effect peeling away. What gives? The effect doesn’t need to be rendered!
    Christoph Vonrhein replied 17 years, 11 months ago 6 Members · 5 Replies
  • Rafael Amador
    October 10, 2008 at 2:36 am
    [Bruce Lambert] “The effect doesn’t need to be rendered!”
    Your Mac is giving you a preview in RT. This doesn’t means that your effect doesn’t need to be rendered. All the effects (filters or motion effects) need to be rendered. Select all your sequence ad click Option-R to force a Render-All.
    Rafael
    http://www.nagavideo.com
  • Bret Williams
    October 10, 2008 at 3:57 am
    True, but exporting to a self contained QT renders all effects. Not in the timeline, but during export to the QT movie.
    Sounds like a weird quirk of the export. Rendering in the timeline first might fix it anyway.
  • Jim Carswell
    October 10, 2008 at 12:11 pm
    There’s also a chance you have a corrupt timeline. Create a new timeline and copy and paste your project into it… render and export. See if that helps.
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
  • Kevin Monahan
    October 10, 2008 at 4:51 pm
    put the clips in the same track and then apply the transition.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Christoph Vonrhein
    October 11, 2008 at 4:14 am
    Some effects look different in preview mode compared to the final rendered video. This is because some plugins use different (speed optimized) routines with a lower quality for the preview mode. It is possible that the filter you use is just buggy.
    Do you use the internal page peel effect of FCP or one from a 3rd party developer ?
    Christoph Vonrhein
    https://www.chv-plugins.com
