Activity Forums Adobe InDesign Page Numbering – Alignment / Placement Problem
  • Page Numbering – Alignment / Placement Problem
    Posted by Luke Renner on December 4, 2012 at 3:52 am
    I designed a document with a pre-built, A4 layout template. The client has since changed the document to 8.5″ x 11″. After doing this I had to move things around a bit to get them aligned inside of the new space. The one thing I cannot figure out how to nudge are page numbers. The numbers are correct… I just don’t like where they rest on the page. Where do I go to nudge them up and down, left and right?
    Naturally, I am under a deadline as well.
    Help!
    Luke
    Dwayne Smith replied 13 years, 9 months ago 2 Members · 1 Reply
  • Dwayne Smith
    December 4, 2012 at 9:25 am
    G’day Luke
    Open your pages panel (Windows > Pages).
    Up the top you will see the page masters.
    Double-click on the relevant master page and you should find the page numbers there.
    Changes made to a master page get replicated to all pages with that master applied.
    If you can’t select the page numbers — check your layers panel to ensure they’re not on a locked layer.
    Hope that helps
    d.
