Activity › Forums › Adobe InDesign › Page insert doesn’t seem to work right…
Posted by Sean Lloyd on September 28, 2023 at 2:57 amHi,
I’m trying to reformat by book, but when I try to insert a page it connects to the following page as two pages facing each other, but the page I was trying to connect it too is left by itself as a single page. I’ve tried a bunch of things and nothing seems to work.
Any ideas?
The photos below show the progression. The first is before. The 3rd shot is where it placed it and the forth shot is the page I was trying to attach to now by itself.
Thanks…
Sean Lloyd replied 2 years, 10 months ago 2 Members · 9 Replies -
Sean Lloyd
September 30, 2023 at 9:19 pmHi,
No one has attempted to anwer this yet. I am really kind of stuck until I resolve this. Anyone with information would be very much appreicated. Thanks.
Sarah Smith
October 2, 2023 at 1:42 pmHi Sean, I’m an InDesign expert and am here to assist you… please take the following steps;
1. on your InDesign software click on the pages panel (by your top right of your desktop).
2. Using the Type tool, click to place the insertion point where you want the break to occur.
3. Choose Type > Insert Break Character, and then choose page break.
this will easily move the text to the next page (creating blank page) without messing up your entire document arrangement.
hope this helps THANKS
Sean Lloyd
October 2, 2023 at 7:34 pmHi Sarah,
Thanks so much for responding to my question. I tried what you suggested several times, but it’s still not working. After what you mentioned I went to layout/ pages/insert page and still the page is left by itself.
I had a similar issue before, but I was able to work around it by creating a new page at the bottom of the document and then moving it, but that is no longer working.
I will try to redo everything from the point where I am resizing the document and see if that helps anything.
If you have any other suggestions let me know, and thanks again for your help. I really appreciate it..
Sean Lloyd
October 2, 2023 at 7:45 pmPS If I open a new document with facing pages and do an insert it works fine, so it must likely be something in my book layout that’s causing the problem…
Sarah Smith
October 2, 2023 at 9:44 pmHi Sean, thanks for the feedback
did you add and link the text fame after adding a new page at the last newly created?
this will enable the texts in each text frame link together. and hope you software is up to date?
i will make a tutorial video for you…. hang on.
Sarah Smith
October 3, 2023 at 10:33 pmHow to create a blank page in InDesign
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Sean Lloyd
October 28, 2023 at 5:17 amHi Sarah.
Thanks so much. I actually think that may have done it. I don’t think I was selecting both sides of the layout like it looks like you did in your video.
I really appreciate it and sorry for the late reply, I’ve been working on other parts of my project and just checked in here tonight.
Thanks, again!
Sean Lloyd
October 28, 2023 at 11:22 pmI think I may have been wrong. Tried it today and it still doesn’t work.
Sean Lloyd
October 28, 2023 at 11:28 pmJust as an update for anyone unfortuate enough to have to have been following this…it works until I use the liquid page rule and scale to resize the whole book, then when I try to insert a page it doesn’t work.
Thanks again for the replies on this thread…
