Activity › Forums › Apple Final Cut Pro Legacy › P2Store troubles
  • P2Store troubles
    Posted by Todd Reid on September 14, 2007 at 4:33 pm
    I’ve read some post on the cow about troubles importing P2 footage with FC6.
    This is the first time since upgrading that I’ve needed to import P2 footage, and I’m having some issues. I’ve imported from same client MANY times prior to upgrade (on their 8gb cards).
    I’ve tried 2 different P2cards and I’m getting the same footage, which will import, but its the wrong footage. Since both cards gave the same footage, I’m thinking that this footage is on the P2Store’s harddrive. i can’t seem to look at the cards.
    I’ve tried several times and got an error message a few times that said I inserted a drive that is unreadable by the computer, but 3 disc images loaded up each time (with or without the error). The footage (that I can import) is the wrong stuff.
    Has anyone been able to successfully load P2 footage from P2 cards in FC6?
    Any ideas?
    As I’ve seen here before many times…..
    PLEASE HELP, DEADLINE early next week!!!!!
    MacBook Pro 2.16 Ghz intel core duo
    Maxed at 2GB Ram
    FCS2
    P2Store – AJ-PCS060
    16 GB P2 R-series cards
    Tom Brooks replied 19 years ago 2 Members · 1 Reply
  • Tom Brooks
    September 14, 2007 at 7:48 pm
    Not sure if there is a P2 driver issue in your workflow–but drivers for 16GB are new. Upgrade software avail from Panasonic.
