Activity Forums Panasonic Cameras P2 xml relinking problem in FCP
  • P2 xml relinking problem in FCP
    Posted by Thomas Anderson on April 7, 2009 at 10:08 pm
    I’m revising a client project from 06 that was shot on p2. I used p2 log to create the xml and associated quicktimes for import. The xmls were later moved into a different folder for archiving the project. In reopening the project clips need relinking. I can search for and located the clip in the reconnect dialog box, but once selected, it doesn’t show up in the lower box of clips to connect. If I reimport the xml I get black blank clips or an xml failed to import due to critical error warning. *!@# %! In the finder my xml is associated with the color app. which I don’t think was around when this project was created. I’m out of ideas, am I S.O.L.?
    Michael Sacci replied 17 years, 5 months ago 2 Members · 1 Reply
  • Michael Sacci
    April 7, 2009 at 11:56 pm
    Did you keep the entire CONTENT folder structure in tact. the xml are just points to the actual footage and audio,
    > = a folder
    ( ) = what is in the folder
    LASTCLIP.TXT
    >CONTENT
    >VOICE (empty)
    > VIDEO (MXF, these are the real video files)
    > PROXY (empty)
    > ICON (empty)
    > CLIP (xml, these are just the pointers)
    > AUDIO (mxf, these are the real audio channels)
