Activity Forums Panasonic Cameras P2 Transfer to Quicktimes, all the files do not convert.
  • P2 Transfer to Quicktimes, all the files do not convert.
    Posted by Anthony Wilhelms on June 12, 2007 at 5:54 pm
    I have a few folders of P2 footage that I am trying to convert to Quicktime.
    First I import the folder with all the P2 contents. Say the folder has 30 clips of Audio=MXF, Clip=XML, Icon=BMP, Proxy, Video=MXF, and Voice. So I add the folder into the Import Panasonic P2 in Final Cut. Then Add Selection to Queue to make Quicktimes. “THE FILES DO NOT ALL CONVERT”. I can see all the files in my Import, but they are not all converting into Quicktimes. Please Help.
    Anthony Wilhelms replied 19 years, 2 months ago 4 Members · 6 Replies
  • Jeremy Garchow
    June 12, 2007 at 6:43 pm
    Before you add the selection to the queue, make sure you select them all (Apple-A) then hit the add selection to queue button.
  • Anthony Wilhelms
    June 12, 2007 at 7:40 pm
    Yes, they were all selected. We watched the files being converted and seeing some being skipped while converting.
  • Jeremy Garchow
    June 12, 2007 at 8:36 pm
    Any errors or warnings? Are you sure they weren’t just short clips? What happens when you watch those particular clips before importing? What do they look like?
    What format is the footage?
    Jeremy
  • Marcus Van bavel
    June 12, 2007 at 10:02 pm
    Try the demo version of Raylight for Mac, I’ve had several customers use it for
    importing troubled cards. See https://dvfilm.com/raylight/mac
  • Guy
    June 14, 2007 at 4:24 pm
    Try unchecking “remove duplicate frames” in the P2 import window prefs.
  • Anthony Wilhelms
    June 15, 2007 at 7:49 pm
    Thanks for the information guys. Found out that the transfer worked when you just drop the clips in, instead of doing an add to.
    Don’t know why, but it worked.
    Thanks for your time.
